primary question
Discussion in 'Transmission' started by hog up, Oct 6, 2016.
  1. hog up
    hog up Member
    22
    13
    02 heritage softail- 60000 miles- took derby cover off when changing oil and noticed clutch is almost touching outer primary cover. not enough room to pour oil in. had to put oil in inspection cover. is it normal for clutch to be out that far? no noise and clutch works fine
    Jack Klarich likes this.
  2. Jack Klarich
    Yup
    The new M8 is a bit different has a funnel slot cut in it fill to bottom of clutch basket 28oz on the nose
  3. Jeff Klarich
    4,796
    103
    484
    I used a long thin funnel and it worked well.
  4. hog up
    hog up Member
    22
    13
    ok thanks.
  5. Jack Klarich
    ;) Get er done
  6. dbmg
    dbmg Guest
    My 08 EG also needs a funnel to fill primary. Don't ask how I know........
    Jack Klarich and HDDon like this.
