Hello first post, I have a 1995 FLSTN, on a recent trip i found my primary was dry. after trouble shooting this i found the oil from the primary going into the crank case and over filling the oil tank (made sure of this with the use of dye) replaced the crank seal but is still doing the same thing. I am planning on sealing the 4 screws that holds the stator wire in place but my question is in the service manual it says with the wet clutch models to turn the seal lip away from the flywheel. so question is Which way does the front of the seal face towards the fly wheel or towards the crank?
Thanks
Thanks
