Primary leak after fluid change
Discussion in 'Sportster Models' started by BikeSAG, Dec 28, 2010.
  1. BikeSAG
    BikeSAG Active Member
    322
    38
    5
    OK, I changed the transmission/primary fluid on my sons 2005 1200, in:shockstalled new gasket, tightened the bolts in a star pattern and found fluid on the garage floor today. Is there a trick that I don't know about? I guess the large gasket slipped during re-installation of the cover plate. Any thoughts or suggestions? I have never had this happen after changing the primary fluid on my Heritage.
    Thanks
  2. y2kflhr
    y2kflhr Active Member
    191
    Not sure but the fluid should be below the cover so I would check the drain plug
  3. Chopper
    Chopper Senior Member
    1,632
    19
  4. jetwrench
    jetwrench Member
    43
    My guess would be slipped or pinched derby cover seal.
