Hi,All.I have a 03 twinn cam 113 it has about 2500 miles on it since motor was done. Has stroker kit in it with screamin eagel cnc ported heads,woods 9fg cams,mukini 42 carb. After i let it warm up good, itake off and if i stand on it,It pings real bad.and also if i dont stand on it and just drive normal for about 12 miles on a 80deg.day it will get up to about 260 before i shut it off to let it cool down.I dont no if the carb. is to small and not giving it enough fuel making it run lean,and causeing it to run hot.Iam taking it this weekend and putting it on a dyno to see if its running to lean or to much timing.Also i noticed when i drive it and it gets hot it has a major amount of top end noise,Like rocker noise,A clatter big time. NEED HELP!!!!!!!! Thanks.
