free website stats program personal code disarming | Harley Davidson Forums
I successfully married the TSSM to my 2006 flhtcu and it works fine with the button fob. But I cannot get the personal code to disarm the alarm. I followed the directions, and it accepted and acknowledged the code I entered. As per the instructions I put the switch to accessory and pressed both turn signal switches at the same time and the alarm icon flashes 3 times per second as it should but that is as far as it goes. I cannot get it to get to the point where you can put the code in to disarm. Am I missing a step, any suggestions would be appreciated.
It should work and timing is everything. Sometimes it takes a few tries till you get the hang of doing it before it works. You have to be fast.
