Part number HD29604-00A
Discussion in 'General Harley Davidson Topic' started by Jim and Tammy, Sep 17, 2008.
  1. Jim and Tammy
    Jim and Tammy Member
    61
    Its a jet kit but I can't find it listed anywhere. Anyone know the specs?
    Jim
    50
    Calibrated for the extra displacement of the Twin Cam 88 engine. Fits 00-up Twin Cam 88-equipped models.
    This is what the kit contains...
    [​IMG]
    Different slide spring, jet assortment, emulsion tube, adjustable needle, drill for removing the idle mixture plug to adjust idle mixture. Don't mix these jets and emulsion tube with the stock pieces. You'll loose some MPG using this kit.
  3. Jim and Tammy
    61
    Thanks Glider!
  4. glider
    50
  5. Jim and Tammy
    61
    Its a done deal. I was having trouble with the bike stalling out while idling at stops and during downshifts.
    I was running stock HD mufflers with the baffles punched out and it was lean.
    I installed Cycle Shack MS-129 slip ons and a K&N 3909 air filter kit. Loaded it in the truck and took it to the dealer to rejet the carb. Thats the kit they used and I could'nt find any specs on the jet kit.
    The bike, (05 FXD),seems to run real good,no stalls and idles nice now.
    As far as seat of the pants performance gains it feels a little stronger but I had hoped for more.
    I need a bigger motor....:D
