part interchange/fitment?? 08 sportster
Discussion in 'Transmission' started by bio_research, Nov 18, 2013.
  1. bio_research
    bio_research Member Contributor
    68
    Will a clutch hub from a 2003 sporty fit my 08? Mine is trashed and I have next to no money to fix it... found one on ebay, but I want to make sure it will fit.
    Thanks,
    Justin
  2. Jack Klarich
  3. bio_research
    68
    THANK YOU! it looks like the 03 will fit!
  4. Breeze3at
    Breeze3at Well-Known Member
    4,926
    224
    There is a difference (I don't know what it may be) between the '03 hub #36785-91 and the '08 hub #36790-04 as noted by the part # difference. The difference may not affect fitment, could be as simple as different rivets, but is worth finding out what it is.
  5. bio_research
    68
    I was actually looking for the interior hub... the part numbers for 2003 and 2008 are : 36785-91
    or am I not looking at it correctly? The part is #11 on the 2003 diagram and #12 on the 2008.
  6. fin_676
    5,789
    153
    288
    I checked through all my sources and it looks like you are correct the clutch hub has the same part number from at least 93 to 06 so it gives perhaps a larger window for finding a replacement part
  7. Breeze3at
    4,926
    224
    My bad, I was looking at the clutch shell, not the hub.
