pan head on a shovel lower
Discussion in 'Engine, Fuel and Exhaust' started by gmcdeadhead, Sep 29, 2013.
  1. gmcdeadhead
    gmcdeadhead Member
    9
    hello. im new to the forum, is it possible to put a panhead head on a lower shovel head motor. the motor i have that i want to do this to is a 1979 1340 shovelhead motor , thanks
  2. tourbox
    tourbox Senior Member
    1,888
    168
    Welcome from So. Texas. Yes it is do-able. The 66-69 was a Panhead lower unit with Shovel jugs. So the cylinder base bolt pattern is the same. I guess you already have the jugs, heads, and rocker boxes? However I don't remember how the rocker boxes got oil.
    tourbox
  3. Breeze3at
    Breeze3at Well-Known Member
    4,926
    224
    Yes it's possible, and not real difficult. There are issues with oil passages and oil lines.
    If you google "Panheads on shovel cone cases" you will get a lot of information. Some good, some notso good.
  4. Jack Klarich
    Indeed it can be done but the oiling system is way different for the heads Shovels oil with external oil lines, up to 1965 panheads oiled up the push rod tubes, the early oil pumps were not the same either
  5. gmcdeadhead
    gmcdeadhead Member
    9
    how would you do the oiling for the pan heads? i want to keep the whole lower shovel complete. i should not have to mess with the lower part at all.
  6. Goatboy
    Goatboy New Member
    4
    I built a bike from the ground up using '73 cone shovel cases, pan cylinders, and STD panheads...not only is it possible, but that engine was the smoothest running rigid mounted engine I have ever ridden. I didn't build the engine, but I did a lotta work on the top end in recent years, don't have it now, but early on, it was outstanding and didn't leak oil.
  7. gmcdeadhead
    gmcdeadhead Member
    9
    did anybody ever put on those sdt heads? are they a direct replacement type head to fit on a shovel head?
  8. Jack Klarich
    stddevelopment.com If you are talking about STD, they are very good parts and have great tech support:s
