HarleyHarry
Banned
How to give pill to cat
HOW TOGIVE A PILL
TO A CAT
1. Pick cat up and cradle it in the crook of your left arm as if holding a baby. Position right forefinger and thumb on either side of cat's mouth and gently apply pressure to cheeks while holding pill in right hand. As cat opens mouth pop pill into mouth. Allow cat to close mouth and swallow.
HOW TOGIVE A PILL
TO A CAT
2. Retrieve pill from floor and cat from behind sofa. Cradle cat in left arm and repeat process.
3. Retrieve cat from bedroom, and throw soggy pill away.
4. Take new pill from foil wrap, cradle cat in left arm holding rear paws tightly with left hand. Force jaws open and push pill to back of mouth with finger. Hold mouth shut for a count of ten.
5. Retrieve pill from goldfish bowl and cat from top of wardrobe.
6. Call friend to help.Kneel on floor with cat wedged firmly between knees, hold front and rear paws. Ignore low growls emitted by cat. Get friend to hold head firmly with one hand while forcing wooden ruler into mouth. Drop pill down ruler and rub cat's throat vigorously.
7. Make note to buy new ruler and repair curtains. Carefully sweep shattered Doulton figurines from hearth and set to one side for gluing later.
8. Wrap cat in large towel and get friend to lie on cat with head just visible from below armpit. Put pill in end of drinking straw, force open mouth with pencil and blow down drinking straw.
9. Check label to make sure pills not harmful to humans, drink glass of water to take taste away. Apply Band-Aid to friend's forearm and remove blood from carpet with cold water and soap.
10. Retrieve cat from neighbour's shed. Get another pill. Place cat in cupboard and close door onto neck to leave head showing. Force mouth open with dessert spoon. Flick pill down throat with elastic band.
11. Fetch screwdriver from garage and put door back on hinges. Apply cold compress to cheek and check records for date of last tetanus shot. Throw away tee shirt and fetch new one from bedroom. Call fire brigade to retrieve cat from tree across the road. Apologise to neighbour who crashed into fence while swerving to avoid cat.
12. Take last pill from foil-wrap.
13. Tie cat's front paws with garden twine and bind tightly to leg of dining table, find heavy duty pruning gloves from shed, force cat's mouth open with small wrench. Push pill into mouth followed by large piece of filet mignon. Hold head vertically and pour half a pint of water down throat to wash pill down.
14. Get friend to drive you to the casualty department, sit quietly while doctor stitches fingers and forearm and removes pill remnants from right eye. Call furniture store on way home to order new table.
15. Consider giving cat to friend and call pet shop to see if they have any hamsters.
