OK, group. Got this code a couple of times on the ride home last night. Happened a couple of times under load when going to near WOT, accelerating at highway speeds.
Looking in the book (Electrical Diagnostic Manual) in section 5.20, it calls for use of a Breakout Box. No gots!! How do I get around that? Or is that something I should have?
In reality, it is a series of test to determine if the spark plug is bad, plug wire bad or coil bad. Seems to me I can just follow that same path replacing first the plugs (just do them both!), then the plug wires, and finally the coils. Between each, see if the problem persists (including before starting to replace anything!).
What do you think?
What do you think?
