outer primary
Discussion in 'FXR Models' started by 1990FXR, Sep 7, 2009.
  1. 1990FXR
    1990FXR New Member
    3
    I NEED THE tightening sequence FOR THE OUTER PRIMARY A DIAGRAM WOULD HELP 1990 FXR
  2. TQuentin1
    4,737
    142
    On my bike ('91 FXDB-S) the book has you starting in about the middle of the primary cover on the two screws (top and bottom) that are just forward of the swell. Then you move in an alternating top-bottom X pattern forward and backward of that line formed by the first two you did. I like to start with by screwing the screws handy with the bit in a screw driver handle. Then I set the torque wrench at 65 in-lbs. and do the pattern. Then I increase the TW setting to 90 in-lbs. and do it again. Finish up with 110 in-lbs.
    PRIMARY HOUSING - 1990 Harley Davidson FXR
  3. 1990FXR
    1990FXR New Member
    3
    ok i read where if not done in the exact order it could warp the primary cover
  4. glider
    50
    Usually it's a cris cross tightening sequence that is covered in the factory manual. Best bet is to get the manual if you are going to work on the bike yourself.
    [​IMG]
  5. 1990FXR
    1990FXR New Member
    3
    thanks thats what i needed thanks again
