I need a set for my '90 softail to get it through the registration inspection in W.A.
Cheers.![]()
You can ask dealer, but when working at dealer we typically tossed O.E. exhaust into dumpster.
Is trying to find EPA compliant exhaust going to get you through inspection?
Cheers Bro.I had a set installed years ago on a scoot and they asked if I wanted then, if not they would toss them.
Thanks for that.If your dealer has none, check E Bay for take offs
It's just for the noise.Is this for sound or emissions? If for sound, then any sort of noise reducing slip-ons will probably do the trick.
However, if for emissions, then what you will probably need to do is to lean out the AFR a bunch. If you have done a high flow A/C, you may need to go back to OEM on that too. And you will need to go back to jets that lean out the AFR. Without a sniffer and the spec they will be inspecting to, it is just a guessing game. Know any indies you can talk to about what will pass?
Cheers,
If it's just a noise issue a set of quieter slip on's will do the trick.Yes. The system on it is too loud for Dept of Transport but not for use on the road. eg: the cops don't bother me.
Cheers Bro.
Thanks for that.
Thanks.
