oil viscosity
Discussion in 'Classic Models' started by peepawandy, Apr 5, 2010.
  1. peepawandy
    peepawandy New Member
    4
    My manual calls for 60wt oil for my 59 Panhead, Can I use like 20/50 synthetic?
  2. Breeze3at
    Breeze3at Well-Known Member
    4,921
    224
    I think no. Heavy viscosity oils were used in older bikes sorta like "spacers", for the large variances in manufacturing tolerances. As good as synthetics are, I don't think they can make up for that. I could well be wrong, and don't mind knowing if I am.
  3. busfreak
    busfreak Member
    20
    No No No you have roller bearings use the 60w. Make sure it cycle oil or at least the Valvoline racing. It contains zinc in it, those old motors need it for lubrication.
  4. peepawandy
    4
    Thanks for the reply. I appreciatle your inmput.
  5. Jack Klarich
    H D 60 should be fine I ran it in my 60 Fl with no problems
  6. BUBBIE
    BUBBIE Well-Known Member
    4,974
    125
    Peep,
    When your older bike calls for 60w straight weight oil... A reason for it.
    I have not checked a lot of oils today but I know Redline makes the heavy "single weights" yet and I would definitely stick with the Viscosity they recommend. That being the 60w
    The 60w is needed to take up the slop that using a 20w50 won't do...
    The oil pump is designed for a straight HEAVY weight oil and the clearances in the engine are designed for the same.
    A big difference in the SINGLE weighted oils than the "multi weight" oils of today...
    mine? I would use the single weight 60w, and a synthetic for the added wear protection and heat...
    The old days 60w harley heavy oil.
  7. NEWHD74FAN
    8,191
    98
    19
    Use the single weight 60 if "normal temperatures"...but if you are running in the 40's or 30's, you may want to consider 50W just to make easier cold weather starting during the winter months. The older engines had more bearings that were roller type and do not need so much oil pressure to "pressurise thin film of oil around thrust bearings and oil gallery grooves" to keep from metal to metal contact...so much more in use today. Also the high detergent levels make thinner oil films and more particles in suspension today possible, more so than in the past.
  8. tkeswede
    tkeswede Member
    76
    18
    When it really gets hot I ran a Catrol 70 wt. But mostly 60 wt. during the normal summer heat. I ran this in a 48 pan I had 25 yrs ago. Sure wish I still had it. Everyone is right about the bearings and stuff.
  9. 59Panhead
    59Panhead Member
    89
    NO 20-50 !
    they didnt run 20-50 until 1984 so st8 60 wt is the right stuff ! I run Amsoil 60 racing oil in my 59 Pan....
    In colder weather I run 50wt. and 70wt if its going to be 90f plus everyday
    dont run multigrade it's to thin !
