oil use on 1992 evolution engine
Discussion in 'Oil' started by steel horse rider, Jul 28, 2014.
  1. i have a 1992 electraglide with the evolution engine which does not smoke so i know its not burning oil but i noticed that after rideing about 300 miles i seem to have to add a quart of oil can anyone tell me what seems to be the problem here
  2. dbmg
    dbmg Guest
    It just might be that the old steed is starting to get a little tired. If no external oil leaks and not using 20w50 you might want to switch.....
  3. Jack Klarich
    If it aint smoking, it must be leaking
    Have a look for signs of leaks
    Special attention to the rear rocker box and base gasket
  4. fin_676
    5,789
    153
    288
    Couple of thoughts as the oil has to be going somewhere have you checked the level of oil in the primary
    Where does the crankcase breather go to as a worn engine can push sump oil out through the breather if stock should be a pipe to the air box but may have been altered if the breather is pointing under the bike could be dumping oil ahead of the rear wheel
  5. Jack Klarich
  6. engine does not leak oil and breather assembly is all original would it be a good idea to use synthetic oil
  7. weldbead
    weldbead Member
    75
    a quart in 300 miles sounds like a lot..if its not smoking it should be visible..
  8. kdaddy
    kdaddy Active Member
    185
    38
    9
    Check your plugs to see if they are black and oily. Your head bresthers may be blowing it into the carb an burning it in the cylinder. Even though its not smoking you should swab the inside of your exhaust and see if you are getting oily residue
  9. fin_676
    5,789
    153
    288
    This is a 92 evo head breathers introduced in 93 this engine will have a crankcase breather goes straight to the bottom rear of the air cleaner box excess oil would exit the box and coat the engine
