oil tank placement
Discussion in 'Oil' started by thumper812, Sep 26, 2013.
  1. thumper812
    thumper812 New Member
    hello everyone I recently bought a 2005 sportster with 1200 bbk installed it was wrecked so I decide to put the engine on a mini buggy my ? is can I mount the oil tank above the engine or below the top of the head I have mounted about where is was from factory but need to put some where higher to protect it. nice forum
  2. HDDon
    5,562
    133
    236
    The tank can be mounted as high as you like. Gravity feed.
  3. Bodeen
    4,647
    73
    222
    Pictures please!
    I would think you could put it a little higher but if you went to far you may end up causing oil issues. Putting it too high at some point would cause the oil pump to have to work too hard. Adding feet of head to the pump will decrease its capacity.
