Oil Sump plug
Discussion in 'Softail Models' started by Tatanka, Jan 15, 2008.
  1. Tatanka
    Tatanka Member
    63
    Is there a plug to drain the oil out of the sump. Or just the one on the oil tank. I have a 2001 Heritage with 50k miles on it. I did not have time to change the oil before cold weather set in, And I would like to give it a good flushing.
    56
    I would suggest not touching the sump plug. It is installed after passage ways in the engine cases are bored and there have been a few that have cracked the case trying to remove it. There should only be an ounce or two in the case unless your engine is sumping and then it is used to determine this condition using care to heat it and remove it.
    Run the bike at idle in the upright position for a minute or two after a thorough warm up to purge the sump, then drain the oil from the tank.
    Best left alone.
  3. glider
    56
    Don't be tempted Joe:s
  4. 07ROADKING
    07ROADKING Active Member
    120
    i was just reading about the case cracking around the sump drain plug :panic
  5. glider
    56
    Must be an ugly feeling to try to remove it and end up with a cracked case. No short way of fixing something like that other than replacing it.
  6. 07ROADKING
    120
    just thinking of it makes me ill :56::shock:17::bigsmiley21:
  7. glider
    56
    :bigsmiley14:Smart man!!
  8. Twisted Grip
    Twisted Grip Banned
    337
    Glider,
    Thank you so much for this info! As Joe said I was wodering my self about that plug, did some reading in the owners manual and it tells you nothing on that plug when changing the oil!
    That would have made for a very bad day and lots of wasted $$$
  9. bb156ny
    bb156ny Account Removed
    52
    I thought I had read some place that you can remove the return hose to the oil tank after an oil change and let the engine idle until the dirty oil purges to new oil ????
  10. glider
    56
    You mean like this?:D
    Complete Oil Change (softail) - Harley Davidson Community
