Oil problem...?
Discussion in 'Sportster Models' started by hoglot2012, Jul 13, 2012.
  1. hoglot2012
    hoglot2012 New Member
    On the 2007 Sportsters a special "O" ring had to be used to stop leakage. Does this apply to the 2008 models as well? The bike is backfiring as well.
    Anyone got any ideas?
  2. Breeze3at
    Breeze3at Well-Known Member
    4,926
    224
    Oil leakage from where?
  3. Bodeen
    4,647
    73
    222
    The more specific information you give. The more help you will receive. Oil from where, which o-ring, what model 2008, what mods on the 2008, stage one, backfiring when? You get the idea. All the information is needed.......
  4. Iceman24
    Iceman24 Well-Known Member
    3,266
    23
    If you're referencing the oil "plug" o-ring then yes it's needed for "all" bikes, or use thread tape (same principle).
    As far as bike backfire, like others, need some background/info.? Is this after a recent mod (pipes, a/c, etc.), or stock bike?
  5. Jack Klarich
    With more info it will be easier to get you the help you seek. The O ring should be at least checked if not replaced every oil change and drain plug torqued to insure no oil leaks. As far as back firing more info is needed as what mods to the bike when does it do it when did it start ETC:s
