One thing I have believed for years and have Seen is, IF an oil gauge was right on top of the pressure LIVE, IT would SCARE most. The
fluctuation of oil pressure is there and NOT just a steady constant pressured flow..
HD's gerotor style oil pump (06/07 up larger pump) are close to the Best style of oil pump IMHO. Just the average Crank Run-Out on these newer bikes is what worries me
anic
Even though I am having an On-Going OCCASIONAL Lack of Start-up oil pressure, I see this New Larger Oil Pump as a good unit.
FLOW is the thing that is needed and also the Larger return gerotors have solved the sumping problem on Many Early bikes with the early smaller pump, simply by Replacing with the "KIT". Upgrading to the New Style Hydraulics is a GOOD thing on the Pre 07 Bikes.
I like the oil gauge on my bike. It is a HD version that Bolts on to the rear valve cover area and I LIKE seeing the affects of HEAT and RPM change with an occasional glance.. Yes I Kept the IDIOT Light as it is called, A NEEDED thing..:newsmile03:
My pressure runs up to 50 lbs cold and all day at 35/38 lbs (gauge) on normal not over 90* days and Not In Stop N Go traffic.
20/50 Redline
