Oil pressure gauge installation
Discussion in 'Oil' started by Jeno', Jul 5, 2017.
  1. Jeno'
    Jeno' Member
    15
    First off thank you guys in advance for any information you give . I have a 2004 Harley Davidson Fatboy and what I'd like to do is put a oil pressure gauge but keep it for the idiot light will still work I have researched with and I (EDIT) with research . I looked up online oil pressure kits but can't tell if any will work and besides the Lines look chintzy. I'd like to try to find it all piece by piece if anybody can tell me what the pieces are called that I all need with a metal line and the size threads I would greatly appreciate it .. Thank you .
  2. 76_shovel
    76_shovel Member
    66
    8
    Unscrew your current oil pressure sensor and plumb in a "T" fitting, put your current sensor back in
    then plumb your oil pressure gauge to the open hole in the "T".
    I think the current sensor is 1/4" pipe. If I am wrong someone will correct me.
    They make "T" fittings where one end is male pipe thread with 2 female pipe thread, with one of these
    you can get a cleaner install.
    Depending on your metal tube size you may need adapter to fit one of the "T" fitting female.
    If using a standard "T" fitting you will probably need a close nipple to fit one end into the engine case.
    Jeno' likes this.
  3. Jeno'
    Jeno' Member
    15
    Ok that I can understand can you also tell me where I would get like a braided line to bring it up to the back of the head???
  4. Jeff Klarich
    Jeff Klarich Experienced Member Contributor
    6,027
    183
    881
    Check online with J &B or Dennis Kirk.
    Edit to bring member's response out of quote box - SledDog
    Jeno' likes this.
  5. Jeno'
    Jeno' Member
    15
    Thank you guys, I really appreciate it....
  6. 90FXRS
    90FXRS Junior Member Contributor
    492
    10
    Jeno' likes this.
