Oil on the forks, 2010 FXDC
Discussion in 'Other Service and Maintenance' started by danthern, Mar 31, 2011.
  1. danthern
    danthern Active Member
    298
    2010 FXDC with 11K and noticed oil on the forks today. Wiped it off, rode 30 miles and its back. Not a lot, but it's there. What's up? I'm thinking that it shouldn't be there. Thanks in advance for any advice.
    More than likely if it was warm out, what you saw was the grease from the steering head bearings. Was it on only the left fork?
  3. Jack Klarich
    Front seals are leaking take it in under warranty:s
  4. Hoople
    Hoople Account Removed
    7,198
    34
    Danthern, Your going to get 3 different answers:) You gotta love this place.!
    "Not a lot but it's there" as in,,, if you were to take a rag and rubbed some oil onto a polished steel bar. The remaining gloss shine looking at it from an angle? That would be normal. I see it on mine. Just an oily shine, nothing more. Not anything you can mop up. Just an oil coat.
  5. danthern
    298
    There's actually a small accumulation, more than just a film.
  6. glider
    Where exactly on the forks is this, on both sides?
    Is it on the fork tubes and does it only go uo a few inches and make a ring or line around the fork tube?
    Common, don't keep us in suspense here, give us some facts.:D
  7. Jack Klarich
    Take it in , my 02 Dyna did the same thing it puked all the way down the leg on to the brakes Warranty issue:s
  8. danthern
    298
    Sorry, I'm at work.....It's on both forks, about like you describe. If I compress the forks with the front brake at low (just rolling) with the forks wiped clean, when they come back up you see the oil. Hope that helps.
  9. JBC2565
    JBC2565 Junior Member
    582
    IMO.... The winner is.......Jack!!
    :bigsmiley23:
  10. danthern
    298
    Thank you gents....I'll have her at the dealership tomorrow.
