Ive found a dual oil gauge adapter. This mounts in the hole that the oil pressure sending unit mounts, at the right rear base of the rear jug. My question is,... I'm wondering if this would be a good place to also mount my thermal oil switch sending unit? By mounting this unit here, with my typical HD oil pressure sending unit. Would it be sufficient at sensing the oil's temperature? My scoots a 1993 EGC. This year doesnt have an additional threaded hole located next to the oil pan's drain plug.
zoood
zoood
