I use a 2 liter plastic pop bottle and make a scoop out of it. I cut the bottom off, then slit it length ways on 2 sides and then cut the top half out leaving the neck. Then slide it under the filter and drill a hole in the top of the filter(at the bottom edge) to drain.
