Oil Cooler Install
Discussion in 'Touring Models' started by Bud White, Feb 6, 2009.
  1. Bud White
    3,270
    Well decided to install the oil cooler tonight maybe a hour to do if that
    Thanks to smitty for the full pic of parts i was to gung ho to install to take that pic
    [​IMG]
    First Remove the old Filter
    [​IMG]
    Then remove the oil filter adapter
    [​IMG]
    [​IMG]
    [​IMG]
    Metric 22mm Socket fits just fine
    Install the gasket on the adapter then install adapter onto engine
    You will need a 7/16 Allen wrench not a common one for the tool box i bought one when i ordered the kit and im a repair man not one i ever used
    [​IMG]
    [​IMG]
    Next remove Volt Regulator and reposition wires The instructs are really lame here ..
    [​IMG]
    Then assemble the Shield Bracket and oil cooler together
    [​IMG]
    [​IMG]
    Hang the oil cooler on the studs for regulator and then hang the regulator
    [​IMG]
    Make sure to space you hose clamps so you can re tighten later if need be
    [​IMG]
    install filter
    Fire it up check of leaks
    I know they say they have a 185 degree thermostat but it seemed to open a bit fast temp was only running about 115 on a thermal gun then dropping fast to re warm up .. i know there is a difference reading outside but that 70 degree difference
  2. R. Lewis
    2,183
    5
    what oil cooler did you put on and did you post any pics. ?? If so , I can't see them ????
  3. gs34
    gs34 Junior Member
    639
    6
    The pictures and description came thru just fine for me. Good job Bud. Thanks
  4. R. Lewis
    2,183
    5
    must be my computer -- not showing your pics. either smitty???? :wall
  5. Bud White
    3,270
    thanks guys
  6. wildspirit97
    wildspirit97 Senior Member
    1,088
    46
    so........I hate to be a pain:D but is anyone gonna post a picture of the oil cooler on the bike?:p
  7. wildspirit97
    1,088
    46
    I saw pics, but not that one till smitty posted it:unsure:dknow
  8. STEVE07
    4,122
    68
    82
    It seems the site is playing different tricks with us .I saw all of the pics. fine
  9. Bud White
    3,270
    ill post a pic of it tomm from the front .. i was to busy running it tonight and listening to the funny noise out of the primary
  10. STEVE07
    4,122
    68
    82
    What funny noise out of the primary?
