Ok guys, heres the scoop. I did drain the tranny, but I meant to. I always use Redline Shockproof tranny fluid. It is bright red and hard to mistake for engine oil. And yes, I did drain the Primary as well. I refilled with 38 oz. of Spectro Primary oil. Yes I do see where it would be easy to mistake the tranny drain plug for engine oil. But I think I found the problem. I unscrewed the allen head plug in the bottom of the engine. I bet the combination allen set screw/bolt in the side is probably the right one. :small3d023: I'll let everyone know how it works out.
