Oil Change Neeed?
Discussion in 'Oil' started by hd4evr, Apr 27, 2011.
  1. hd4evr
    hd4evr Banned
    181
    I only had about 1200 miles on the oil in my bike (Mobil One V-Twin) when I put it away last fall. Now it looks like I'm going to need back surgery, which means I'll probably only get about 2000 miles on my bike this summer, if that, since I can't ride very far or long at one time.. Do you think it will be OK to run that oil all summer and change it this fall, even though it will be over a year since the last change? The bike will only have about 2,500 to 3,000 miles on the oil. Can I just run the Mobil One V-Twin til this fall? Seems like it wouldn't hurt, but what do you all think?
  2. Animal
    Animal Active Member
    385
    Yes the oil will be fine. There are some people who would change the oil for one reason or another but I think an oil change is not needed, once again for one reason or another.
  3. sharpscuba
    sharpscuba Banned
    945
    If it were me and my 07 FLH I would just go for it and ride it out.
  4. JBC2565
    JBC2565 Junior Member
    582
    How far or how long at one time? The oil likes to get up to temp to burn out moisture or anything else. If it was me, I would have changed for winter storage.
    Not sure if you change the oil yourself, but if you do, I would change it. If I had to take it to a mechanic, not sure that I would.
    To be honest, I think you'll be fine waiting till fall. (your ride). Just don't ride it for 10 minutes and then shut it down. I would get in at least 1/2 an hour ride to get it all warmed up.
    Hope your back gets better.
  5. BUBBIE
    BUBBIE Well-Known Member
    4,974
    125
    Now it may seem wrong to some but I'll go with I would run it. 1200 miles is not much on that oil.. Different circumstances I MIGHT do it different..
  6. bcortani
    bcortani Active Member
    392
    3
    I agree with the general consensus here. I switched last fall to the Mobil 1 V-twin and prior to the change, I researched the oils (dino and fake stuff) and learned taht you can actually go about twice the normal miles on the good Mobil V-twin. I will still always change it once a year becaue I should average about 2-3k a season (put 2k on last summer Aug-Oct). If I were in your position, i would sleep soundly leaving the oil in until this fall. If you have a longer recovery time and don't get as many miles as you are expecting, I would sleep well leaving it in over the winter and maybe changing mid summer or next fall. The newer synthetics are really well made and bullet proof. Of course it would depend on the type of riding you do for the miles you are able to put on it this summer. Hope your surgery goes well and you recover quickly.
  7. Bodeen
    4,647
    73
    222
    Change it before you lay it up for the winter.
    Bodeen
  8. glider
    50
    Change it and the filter after the summer riding before winter lay up. Keep the battery on a tender too when you aren't using the bike.
  9. Bodeen
    4,647
    73
    222
    If you go to the top of the page to "menu jump" and go to "store". First item on the list is a battery tender for $15.90. A great deal on a good product.
    Bodeen
  10. hd4evr
    hd4evr Banned
    181
    Thanks guys! Already have the battery tender, keep my bike on it whenever I park it. Not sure how long I'm gonna be off the bike but I'm gonna try to ride as much as I can. I usually ride no less than 20-25 miles when I go out for a "quickie".
