BUBBIE
Well-Known Member
I have had this problem with my 2000 also. I tried the venting to the ground trick but found that it actually pulled the oil out? LIke a venturi action? I put things back to stock (rubber tubes shooting into carb throat) and clean the filter regular . So far the puking of oil has been reduced. I did order the bypass kit that sends the return or vent from the cam chest straight to the oil filler spout. It hasn't come yet so we'll see. I will also realign my oil pump (although I did that when I did my 95 conversion and put cam chain tensioners in) and replace breather umbrellas in my heads. Not sure what else to do?
DID you go with the KIT or equivalent???( i know i have asked this before)
THE NEW HD pump n cam plate that come with the newer style HYDRAULIC tensioners or JUST replace the pump n shoes with stock HD parts?
I had the OIL problem in my 2000 UNTIL A LARGER VOLUME OIL PUMP WAS USED.....THEN i used fueling for 400$$ and todays KIT for MOST needed stuff is 429.$$$
I did have FOAM from the crank area(too much sump oil) and pushing into the heads.. WITH the higher volume pump that QUIT..(.)
I know for a fact (in my case) that the stock OIL PUMP didn't take out ENOUGH oil (SUMP) fast enough and my engine was foaming from the TOO MUCH at the crank.....
A lot of BLOW-BY will ALSO cause the same condition of blowing oil out INTHRU the banjo bolts in heads to the AIR CLEANER.... in that case a direct flow of VENT pressure from engine will help...
