I'm installing the HD camplate upgrade with SE 204 cams. I'm using the existing pushrods and while tearing everything down, I notice a small leak on my front head. It's just an oil mark where the head meets the cylinder. Bike ran great just was doing the tensioner upgrade.
Bike is an 2003 FLHRI Road King with 28K and motor is bone stock except for a stage 1 upgrade. I wasn't planning on tearing it down to this extent.
1. Do I replace the one head gasket or do I do both?
2. If I do both should I use a .030 gasket with the 204's and will it make a difference? I've checked out the calculators but they might as well be in a foreign language. Don't know what they tell me.
3. If I just do the one gasket I'm guessing I need to use an OEM gasket to keep the tolerances the same between the two, correct?
Thanks in advance, this forum has been a huge help to me over the years.
