free website stats program OEM Specs | Harley Davidson Forums
OEM Specs
creepr
I've been all over the web looking for a listing of specs for my stock 2000 XL1200S. I am planning a customization and need this info. Any help on where to obtain such information would be greatly appreciated.
What specs is it that you need?
Something like this help?
Designation: XL1200S
Suggested base price: $8395 ($8515 CA)
Standard color: Black
Extra cost colors: NA
Standard warranty: 12 mo., unlimited miles
Recommended service interval: 5000 miles
ENGINE & DRIVETRAIN
Type: Air-cooled, 45-degree tandem V-twin
Valve arrangement: OHV, 1 intake, 1 exhaust valve; operated by pushrods, hydraulic adjusters
Displacement, bore x stroke: 1200cc, 88.8 x 96.8mm
Compression ratio: 10.0:1
Carburetion: 1, 40mm CV
Lubrication: Dry sump, spin-on filter, 3.0 qt.
Minimum fuel grade: 87 octane
Transmission: Wet multiplate clutch, 5 speeds
Final drive: Belt, 61/29
CHASSIS
Wet weight: 537 lb
GVWR: 948 lb., 51% rear wheel
Wheelbase: 60.2 in.
Overall length: 87.7 in.
Seat height: 28.0 in.
Rake / trail: 29.6 degrees / 4.6 in.
Wheels: Cast, 19 x 2.15 in. front, 16 x 3.00 in. rear
Front tire: 100/90-19 Dunlop D591F Elite SP tubeless
Rear tire: 130/90-16 Dunlop Elite K591 SP tubeless
Front brake: 2, single-action, single-piston calipers; 11.5-in. discs
Rear brake: single-action, single-piston caliper; 11.5-in. disc
Front suspension: 39mm stanchions, 6.1 in. travel, adjustable for spring preload, compression and rebound damping
Rear suspension: 2 dampers, 3.15 in. travel, adjustable for spring preload, compression and rebound damping
Fuel capacity: 3.3 gal., (0.5 gal reserve)
Handlebar: 27.6 in. wide, 1.0 in. diameter
Inseam Equavalent: 32.8 in.
ELECTRICAL & INSTRUMENTATION
Charging output: 266 watts
Battery: 12v, 18 AH
Forward lighting: 5.5-in 55/60-watt headlight, position lights
Taillight: Single bulb
Instruments: Speedometer, tachometer, LCD odometer/tripmeter; warning lights for high beam, neutral, oil pressure, left and right turn signals
PERFORMANCE
Fuel mileage: 31 to 48 mpg, 39.9 mpg average
Average range: 132 miles
RPM at 60 mph, top gear: 2800
200 yard, top-gear-acceleration from 50 mph, terminal speed: 65.6 mph
Quarter-mile acceleration: 13.39 sec., 95.2 mph
