Odometer LCD display bleeding
Discussion in 'Sportster Models' started by capnjapseye, May 28, 2015.
  1. capnjapseye
    capnjapseye Member
    34
    Hi All
    I'm back
    I've just bought my fourth Sportster, a 1997 XL1200S with less than 10,000 miles from new. A lovely bike in black. There are a couple of problems I've noticed:
    1. The odometer LCD display is bleeding, I'd like to get this fixed, does anyone have experience of fixing this? Even if it comes to a new speedo unit, can the mileage then be set to the current value?
    2. High beam warning light not working, is this a fairly simple fix?
    Also, is it normal on the 97 Sportster that the side stand deployment doesn't cut the engine?
    Cheers in anticipation
    Cap'n
    [​IMG]
  2. tourbox
    tourbox Senior Member
    1,888
    168
    I don't think the bleeding is repairable. A new speedo is about $500.00. The dealer or MoCo can set the odometer to original miles. Your high beam indicator is a bulb and can be replace. I don't think there is a side stand Kill switch, I've only seen those on Import bikes.
    tourbox
  3. capnjapseye
    capnjapseye Member
    34
    Thanks for the info, I've done some research on the Net and also found a Eyezon Guages in the USA who can do a repair by fitting a new LCD screen.
    Unfortunately, I'm in the UK
    I have also read a post where a guy has repaired two gauges by fitting the LCD screen from a donor, used speedo. So, I may look at that option too.
    Cheers
    Cap'n
