My 76 shovel that I bought as a basket and put together 5 or 6 years ago always had solid lifters. I decided to put in Hydraulics this fall and when the engine is cold it sounds like a fine watch, but as it warms up the front exhaust lifter collapses at idle. I switched the lifters from hole to hole to see if the noise would change hole. but it didn't. I run 50 wt for oil and have plenty of pressure. Its getting oil everywhere. It has me baffled. I ended up putting the old lifters back in for now. The motor has about 10000 miles on it with no problems. Any light bulbs go on all ideas appreciated!
Welcome to the forum RBREGN I can't help you but I'm sure there's enough knowledge here to keep your bike going for another 100 years.
I would think along the lines of oil supply to that lifter bore or binding in the rocker area being that swapping of the lifters does not migrate the problem.
