no start just clicking
Discussion in 'Electrical' started by short, Jul 26, 2014.
  1. short
    short Member
    15
    When start button is pressed,and green wire from relay is not connected to solenoid 12.7 volts dc is present,but when relay is hooked to solenoid 0 volts just clicking from relay any ideas
  2. 03HD883R
    03HD883R Active Member
    167
    I wouldn't necessarily judge the voltage output to be the final verdict on the battery being good or not. I'd have it load tested.
    Either that, or it's the starter relay or the starter itself.
  3. Bodeen
    4,647
    73
    222
    Are you measuring that voltage at the battery?
  4. Jack Klarich
    Jump across the solenoid does the starterspin? If so the fault is up the line
  5. bikerdad
    bikerdad Junior Member
    506
    38
    10
    check the ground to both the battery and starter solenoid.
    [​IMG]
  6. wazzle
    wazzle Member
    98
    Not sure what kind of starter is on your bike but the one on my 06 and my 13 are Nippedenso starters. There are brass contacts in the solenoid that wear out. They are replaceable in the automotive starters and would assume they are on these too. That is the symptom, just a click.
  7. flst89
    flst89 Member
    52
    18
    4
    This scenario indicates a high resistance somewhere between the (+) battery post and the end of the green wire.
    When the wire is disconnected, there is very little current flowing so the voltage will appear normal.
    When you connect the wire, the component draws as much current as it can, and since there is resistance upstream, the voltage drops at the point of resistance and downstream, that is why you see low voltage when the green wire is connected.
    This type of fault can drive you crazy because when you unplug the component and check for voltage at the connector, it appears normal.
    When measuring voltage drop, always measure with the circuit energized, and complete (no connectors disconnected).
    Note: thanks to Bodeen, for removing my earlier (inaccurate) post.
