CHX Fat Boy
Intermittently, my turn signals, brake light AND horn won't work on my 2007 Fatboy. Typically I can turn the ignition off and on and everything works again. Yesterday I was not able to get anything to work and today everything works again....
I replaced the TSM 2 years ago when I had a similar problem and was ready to order another today until everything started working again. Now I'm not so sure it is the TSM. Maybe the ignition switch...? Turn signal switch...? Not sure if one fuse covers all the circuits noted above, however, I suppose that could be the culprit as well. Not likely though.
Any ideas will be appreciated.
