Night Stand
Discussion in 'Touring Models' started by thomas123, Nov 28, 2009.
  1. thomas123
    thomas123 Member
    5
    Anyone put on the - under the bike - "night stand" ?? And: do you like it ?
  2. Dr. Dolittle
    6,404
    118
    29
    Not sure what it is - do you have photos or a link to its description?
  3. fireman54
    fireman54 Member
    39
    Do you mean the center stand?
  4. thomas123
    thomas123 Member
    5
    Should have stated "Display Stand"
  5. sandmar
    sandmar Active Member
    147
    ah.........now I see,thanks for the pic.
  6. btsom
    btsom Active Member
    351
    38
    I have one in the box, never installed for 2008 Road King. I bought the stand before I realized the machine is so heavy I don't believe I could get it up on the stand in the first place. Second, I believe it would complicate access to the drain plugs for the engine, trans, and especially the primary chain case. I'm too lazy to want to remove the stand for each maintenance procedure.
    So, if even after this review, anyone might want it, let me know. It was a little over $300 at the dealer.
  7. wildman9
    wildman9 Active Member
    144
    It could also interfere with your bike jack if you use one. I know my center stand does.
  8. 06rdking
    06rdking Banned
    152
    I have the same stand as in the pic and its great! dose not get in the way of anything. works great for cleaning, takes up a lot less room in the garage when its standing stright up during winter storage. and lastly the legs are fully adjustable and that makes it easy to put up on stand.
  9. dhorne
    dhorne Active Member
    258
    I have the center stand and it is great , also gives you more assurance when you are parking on softer ground ,better also for doing maintanence , doesnt get in the way of the jack if you leave it down and jack the bike up..all around good investment
  10. Breeze3at
    Breeze3at Well-Known Member
    4,922
    224
    We have opinions on mixed products here. The poster asked about the HD "display" stand that attached to the front of bike and does not lift the bike more than a little. Bolt heads are the resting point, and will sink into any kind of dirt. The other stands take weight off wheels and mount in center, also have fatter resting points.
