NEW 89 sportster carb issues.
Discussion in 'Sportster Models' started by pike1612, May 23, 2010.
  1. pike1612
    pike1612 Member
    34
    "Dead Spot" up to 1/4 throttle."misses""stumbles" upon acceleration up to 1/4 throttle.Will not maintain 1/4 throttle upon acceleration or at highway speeds at 1/4 throttle.Once past 1/4 throttle it runs like it was shot with nitrous..I have-Replaced vacuum piston,cleaned and inspected the pilot jet,main jet,needle,float needle and seat,accelerator pump diaphragm,adjusted float level to 18.5mm,tested the floats for bouyancy,checked for intake manifold leak,checked the piston slide for smooth travel,removed and cleaned the fuel tank,and replaced the o ring in the float bowl.What am i OVERLOOKING?
    What size low speed jet are you using?
  3. pike1612
    pike1612 Member
    34
    Im am using the stock jet 42
  4. glider
    Try upping it to a 45 or 46 jet.
  5. pike1612
    pike1612 Member
    34
    will do brother-i will keep ya posted.
  6. glider
    Good deal.:D
  7. pike1612
    pike1612 Member
    34
    I changed it today to a 45" ..much better but still a dead spot between 45-50 mph. i may adjust the float level a tad to try to compensate or just order a 46' jet.im ALMOST there bro :)
  8. fin_676
    5,776
    153
    284
    You may be able to smooth out the flat spot by raising the the slide needle by placing a couple of washers under it
    that will raise the area of the taper that is being used in comparison to slide height so gives a wee bit more from the main jet through all throttle positions
