free website stats program Neutral Light Help please | Harley Davidson Forums
2001FLHT
I changed the top transmission cover with a new aftermarket chrome one. Now the neutral light is on in 5th gear. I tried adjusting the switch that mounts in the side of the cover, but it either works in neutral and 5th gear both, or does not work at all....any help appreciated...2001 FLHT..
If it worked properly before the change, I would double check to see if you got the right part number for the cover. Generally there isn't any adjusting to do with the switch.
