Well I started to have some idleing issues on my 07 RKC.....so I went to the self help section and found out about the IAC and how to clean it ..... so I do ,I just used brake cleaner.......well after I did this the bike didnt want to start ....so while I'm holding the starter button the starter made a funny noise kinda like a grinding ...well the bike fainaly started and I kept shuting it off and restarting it the starter sounded as it always does fine but that grind sound it made on a long effort has me wondering should I pull the starter and check the pinion gear ??? or can I remove the primary cover and inspect the starter pinion and the clutch ring gear at the same time....Ive been wanting to pull the primary cover and check the tensioner and change the primary lube anyways ....oh and if I do pull the starter the manual says to be careful not to loose the dowel pins ....what do you gear heads think??
Keith
Keith
