Motor rebuild
Discussion in 'Softail Models' started by ricks2006, Jul 20, 2010.
  1. ricks2006
    ricks2006 Member
    52
    I just gut my motor rebuild at hemrick performance and man what a difrence he used woods cams TW6-HG "98"ci kit from revolution performance D&D 2 into1 with stock baffle ported heads new valve springs,push rods,new lifters,S&S super "E" carb ported intake the motor made 105.9HP and 122.9 max torque @5500 r.p.m.He has a very good web site and loves fuel injection his web site is harley davidson drag racing race horsepower nitrous cylinder head porting camshaft twin cam dyno dyn He is in kernerville N.C. real easy to find.
    :D
  2. Hoople
    Hoople Account Removed
    7,198
    34
    Sounds like an Awesome rebuild. I heard some good things about Revolution Performance nickel-silicon carbide plated cylinders. They are suppose to run 25 degrees cooler than factory stock cylinders. If you would, post if you find that to be true. Twenty five degrees is a lot and you should notice it.
    Good Luck with your new Engine.
  3. ricks2006
    ricks2006 Member
    52
    HI Hoople I have put about 1000 miles on this build and so far as to what I can tell it run about 20 degrees cooler than before and that is in 90 plus weather so I'am guessing your right. I as not aware of the difrent when the motor was being build. (didn't know they made 98" kit)
  4. HDDon
    5,542
    133
    229
    Ricks, could you post the dyno sheet? I sure would like to see where the torque and HP #'s are happening. I would really like to see AR line. Thanks
  5. ricks2006
    ricks2006 Member
    52
    This is a copy of the dyno sheet that I have.
    [​IMG]:s
