I found the link to the MMI idle adjustment but found conflicting information on where the 5 and 15amp fuses are. I have a 1996 ultra I have check under both side plates and found that the clutch side has the cruse control box and the triangle shape fuse panel with labled fuses for CB and pod. The brake side has the ECM, 2 relays, a Data link port, and the only 5 and 15 AMP fuses that i can find. The only problem is the two fuses go into a rubber block with no wires that connect to it. Is this right?
