MityVac Brake Bleeder...
Discussion in 'Wheels' started by Mavagrand, Mar 23, 2012.
  1. Mavagrand
    Mavagrand Senior Member
    1,250
    12
    ...is awesome. In all my 48 years I have never bled brakes as quickly or as cleanly as I just did with a MityVac. This thing is amazing. What's even better, I found it at Harbor Freight for 34.00. Great price for a great piece of hardware. It took me ten minutes on each caliper on my 08 EGC. It makes bleeding brakes truly an easy one man job. Anybody in central Florida need their brake fluid changed?? Hehehe
  2. fin_676
    5,788
    153
    287
    I have used my mityvac a few times when working on the car although i always seem to pull air bubbles into the tube as it does not give a perfect seal on the bleeders so i always finish in the old fashioned manual way but perhaps one day i will fully trust it as the manual finish shows no air
  3. Mavagrand
    1,250
    12
    Bubbles in the tube is no problem as long as you keep a vacuum in the tube, the bubbles get pulled away from the calipers. My tube had bubbles in it too, but brakes are working great.
  4. dbmg
    dbmg Guest
    Glad it worked out for you, but I prefer gravity bleeding..
  5. Jack Klarich
    :D Old ways still work good :D The Mighty Vac is a good tool for lots of years of solid work:s
  6. 03fxsti
    03fxsti Active Member
    117
    I tried a mighty van and thought it was pretty good. Recently I started using speed bleeders. Talk about making life easy! They have a check valve built in, fluid come out, no air goes in. I like this process better than the Mighty Vac.
    I am not affiliated with speed bleeders, just really like the product.
  7. jdaws
    jdaws Active Member
    150
    I use the back bleed method. Learned it many years ago working on car/truck hydraulic clutches. You force the fluid from the bleeder up to the master.
    I use a small (new and clean) hand pump oil can.:s
