If you have a no start condition on your motorcycle with Delphi fuel injection.
The problem occurs one time and does not return, so is difficult to diagnose. When the condition occurs, a P1010 code or missing password, is normally set. There have been a some reports of a P1009 code - incorrect password also. It appears the turn signal module did not get a complete message from the ecm at ignition ON so the engine starts
and stalls or cranks but will not start. Try removing the ecm and security fuses, wait ten minutes and reinstall the fuses. This "reboots" the turn signal module and the motorcycle will then start from that point on. The historic codes and the light will remain for 50 starts or until they are cleared.
