free website stats program Maintenance Parts Listings | Harley Davidson Forums
glider.
BOT Machine
Some handy parts lists courtesy of "Chopper"
Spark Plugs​
1000 MILE SERVICE
Syn. 3 - QT. # 9924-03/00QT - Barrel - #99826-03 Formula + -qt. # 99851-05
XL (1) OIL FILTER, CHROME, - 63796-77A, BLACK,- 63805-80A
(3) 20W50 MOTOR OIL- 99816-2050 - 2004 & later (4)
(1) Formula + - 99851-05
(1) O-RING - 11105
(1) CLUTCH COVER QUAD RING - 25463-94A
(1) INSPECTION COVER O-RINGS - 11188 - 2003 & earlier
(1) INSPECTION COVER GASKET - 34986-04 - 2004 & later (replaces 11188)
(2) O-RING - 11171
(1) Inspection gasket 34986-04 (all 2004 & later)
DYNA
(1) 2004 & 2005 Models - (1) O-RING - 11324
(1) 2003 & earlier - 739A
1999 & LATER MODELS
(1) OIL FILTER, CHROME, PREMIUM - 63798-99, BLACK - 63731-99
(2) Formula+ - 99851-05
(2) O-RING - 11105 - 2006 & later (3) - 11105
(1) GASKET, INSPECTION COVER - 60567-90C - 2006 & later - None
(1)CLUTCH COVER Gasket - 25416-99C - 2006 & later 17369-06 w/ three 11105
ALL EXCEPT WIDE GLIDE (1) 0-RING - 11117A - (2) 2003 & later
1998 & EARLIER MODELS
OIL FILTER, CHROME 63813-90
(1) CLUTCH COVER GASKET - 25416-70A
(3) SEAL WASHERS - 31433-84A
SOFTAIL (1) 2004 & later Models - (1) O-RING - 11324
(1) 2003 & earlier - 739A - (2) 1999 & earlier
2000 & LATER MODELS
(1) OIL FILTER, CHROME - 63798-99, BLACK-63731-99
(2) Formula + - 99851-05
(2) O-RING - 11105 - (2000 & later)
[1] CLUTCH COVER Gasket - 25416-99C
1999 & EARLIER MODELS
(1) OIL FILTER - CHROME - 63796-77A , BLACK - 63805-80A
(1) CLUTCH COVER Gasket - 25416-70A
NO O-RINGS - 11105
TOURING (1) O-RING - 2004 & later Models -11324
1999 & LATER MODELS
(1) OIL FILTER, CHROME - 63798-99, BLACK - 63731-99
(4 20W50 MOTOR OIL- 99816-2050
(2) O-RING - 11105
(1) INSPECTION COVER GASKET - 34906-85D
(1) CLUTCH COVER Gasket - 25416-99C
(1) OIL FILTER - CHROME - 63796-77A, BLACK - 63805-80A
FXR (1) OIL FILTER, CHROME - 63796-77A, BLACK - 63805-80A
(2) O-RINGS - 11105
(1) GASKET, INSPECTION COVER - 34906-85D
(1) O-RING - 11117A
(1) 739A
V-ROD (1) OIL FILTER - BLACK - 63793-01K
(4.5) 20W50 MOTOR OIL - 99816-2050
2500 MILE SERVICE & 7500 MILE SERVICE
XL (1) OIL FILTER, CHROME - 63796-77A , BLACK - 63805-80A
(1) CLUTCH COVER QUAD RING - 25463-94 A
DYNA 1999 & LATER
(2) O-RING - 11105
(1) OIL FILTER 63813-90
SOFTAIL 2000 & LATER
(1) OIL FILTER, CHROME - 63798-99 , BLACK - 63731-99
(1) O-RING - 11105
1999 & EARLIER
(1) OIL FILTER , CHROME - 63796-77A, BLACK - 63805-80A
FLH 1999 & LATER MODELS
(1) OIL FILTER, CHROME - 63798-99 -Black - 63731-99
(4) 20W50 MOTOR OIL- 99816-2050
(1) O-RING - 11105
(1) O-RING - 11105
5,000 / 15,000 MILE SERVICE
(2) O-RING - 11171
DYNA
1999 & LATER MODELS
(1) O-RING - 11105 - 2006 & later (1) - 11105
SOFTAIL 2000 & LATER MODELS
(1) O-RING - 11105 - (2000 & later)
NO O-RINGS - 11105
TOURING 1999 & LATER MODELS
(1) O-RING - 11105
(1) O-RINGS - 11105
(2) O-RING - 11117A
10,000 MILE SERVICE
XL (1) OIL FILTER, CHROME - 63796-77A, BLACK - 63805-80A [STD/HUG/SPORT]
(1) O-RING - 11105
(1) INSPECTION COVER O-RING - 11188 - (2004 & later - 34986-04)
(3) O-RINGS - 11171
(2) SPARK PLUGS, 6R12 - 32362-04
(4) SPARK PLUGS, 6R12 - 32362-04 {SPORT MODEL ONLY}
(4) WHEEL BEARING SEALS - 47519-83A
DYNA
(1) 2004 & 2005 MODELS - O-RING - 11324
(1) 739A - 2003 & earlier
1999 & LATER MODELS
(2) SPARK PLUG, 6R12 - 32362-04
(1) OIL FILTER, CHROME, - 63798-99 - Black - 63731-99
(1) O-RING - 11105
(1)Clutch Cover Gasket - 25416-99C - (1) 17369-06 w/ three 11105 2006 & later
(1) Oil Filter - Chrome - 63796-77A - Black - 63805-80A
(2) SPARK PLUGS, 5R6A - 32342-04
(4) SEAL WASHERS - 31433-84-A
(3) 20W50 MOTOR OIL - 99816-2050
(1) O-RING - 11105 (1) Formula + - 99851-05
(5) SEAL WASHERS - 31433-84A
(1) O-RING -11117A
(1) 739A
(2) Spark Plugs, 5R6A - 32342-04
SOFTAIL
2000 & LATER MODELS
(1) 739A - 2004 & earlier models
(2) SPARK PLUGS, 5R6A - 32402-04
(1) CLUTCH COVER O-RING - 25416-70A
TOURING 2004 & later Models - O-RING - 11324
1999 & LATER MODELS
(1) 739A - 2003 & earlier Models
(1) OIL FILTER, Chrome, - 63798-99 - Black - 63731-99
(1) O-RING - 11105
(1) CLUTCH COVER GASKET - 25416-99C
(2) SPARK PLUGS, 10R12A, 2 PACK - 27671-01K
V-Rod 12,000 Mile - Valve Lash
(1) CVR DURBY O-RING - 11130K
(1) TRROTTLE BODY GASKET - 29439-01
(3) CAM COVER GASKETS - 17416-01KA (0)
(2) CAM COVER GASKETS - 17418-01K (I)
(2) CAM COVER GASKETS - 17666-01K (U)
20,000 MILE SERVICE & 40,000 MILE SERVICE
ALL 10,000 MILE PARTS PLUS THESE
XL (2) SCREWS, WITH WASHERS- 45790-80
(2) O-RING 45984-87
(2) FORK OIL-TYPE "E" - 99884-80
1200 SPORT
(2) O-RING KIT 45985-96
DYNA
(1) O-RING - 11105
(2) SCREWS, WITH WASHERS - 45790-80
(2) RUBBER WASHERS - 45733-48
(2) FORK OIL-TYPE "E" - 99884-80 - (4) 2006 & Later Models & NO - 45790-80
WIDE GLIDE USES (2) SCREWS -- 45858-77 INSTEAD OF 45790-80
FXDX & FXDXT (2) O-RING KIT - 45985-96
(1) O-RING - 11105
SOFTAIL (2) SCREWS, WITH WASHERS - 45858-77
(1) O-RING - 11105
FXSTD (3) SCREWS, WITH WASHERS - 45790-80
(1) O-RING - 11105
FXR (2) O-RING - 45982-73
(2) SCREWS, WITH WSAHERS - 45790-80
(2) FORK OIL - TYPE "E" - 99884-80
(1) O-RING - 11105
V-ROD 10,000 MILE SERVICE PARTS
TOURING
(1) O-RING - 11105
30,000 MILE SERVICE
V-ROD
(1) FORK OIL - TYPE "E" -99884-80
(2) O-RING - 46508-01
(1) COOLANT - 99822-80
50,000 MILE SERVICE
Syn. 3 - QT. # 9924-03/00QT - Barrel - #99826-03 Formula + -qt. #99851
FLH 2002 & LATER
2002 & LATER FAIRING MODELS
(1) O-RING - 45845-77
2001 & EARLIER MODELS
(2) O-RING - 45443-86
AIR FORK MODELS - NO RUBBER WASHERS
NOTE;
SYNTHETIC LUBRICANT SAE20W50 - 99824-03/00QT
MAY BE USED IN PLACE OF 20W50 MOTOR OIL- 99816-2050,
SPORT TRANS FLUID - 99896-88, PRIMARY CHAIN CASE LUBE - 99887-84,
TRANS. LUBE - 99892- & Formula + - 99851-05
