nascar7613
1999 Wide Glide. Grinding noise on primary side when moving. Noise goes away when I pull the clutch in. Pulled the clutch & compensator and can hear grinding noise when turning the mainshaft by hand. Haven't pulled the inner primary yet, but suspect the mainshaft support bearing. Can the mainshaft support bearing be removed without removing the gearset? Probably not, just wanted to throw it out there to you guys.
