I hear ya on the additives. I dont beleive in using them, they simply mask a problem that needs fixing.No doubt Lucas Syn 20-50 is a good product.
Few things to be careful of judging oil by sounds is miss leading.
M1 will cause a bit more engine noise (compared to standard oils) but hard to find a better engine oil.
Today's engines need oils that flow better the old days of running a thicker oil to quiet things down just do not work anymore.
I run Spectro only because I like the company, I have often noted it does have less upper engine noise and seems to hold a slightly higher oil pressure when hot.
Of course none of this makes it a better oil just a bit different.
One thing I would avoid is any of the oil or gear lube additives they offer. I have seen some test that show it causing sever foaming in motorcycle engines and gear boxes.
on super or RON92 and carburettor... h2o??Tobaman, are you running premium gas, and are you running EFI (w/fueler) or Carb (w/enriched jetting)? May also want to check the plugs and possibly use decarboning combustion chambers using H20...![]()
yep only in traffic jams. after getting out the traffic jams, i kinda have to open the gas slowly to reach higher speed to get more air so that the engine gets air. usually after getting cooled down, no more knockings.High temps. The knocking is most probably detonation from high cylinder temps.
Only does it in stop-n-go, so engine gets hot and knocks.
wilks3
