Lowering Softail Deuce rear
Discussion in 'Softail Models' started by twhoodoo, Feb 20, 2009.
  1. twhoodoo
    twhoodoo Member
    24
    I want to lower the rear on my Deuce (2001) 1-2 inches with something that is adjustable throughout that range. What do I need to do this and what is the best way? The add on pieces to the stock shocks or complete shocks? I have seen the narrow ones and I do not know what the difference is:small3d023::wall. I want the best for my baby and want to do it right the first time. Thought about lowering the front but have just about decided against that.
    Thanks all,
    PoPpy
  2. twhoodoo
    twhoodoo Member
    24
    Other than air ride what are my other options? Not crazy about the air ride thing, probably something I'll wish I had thought more about later.
    PoP
  3. rancid
    rancid Active Member
    257
    yeah if u want it LOW go for a good but pretty expensive air ride, the cheap ones wont last long n r more trouble than their worth. air rides r quick n easy to lift and drop and firm or soften the the ride
  4. twhoodoo
    twhoodoo Member
    24
    What about the lowering shocks. what brand are the good air shocks and what brand would the regulare lowering shocks be? Thanks for your continued help.
    PoPpy
  5. joe what
    joe what Member
    5
    progressive 422 shocks will lower your bike and comfy ride..
  6. chopper blue
    chopper blue New Member
    4
    Get the arlenness Softail lowering kit studs .You can go from stock to ride on swingarm bumper. $ 75.00.
  7. bhood03
    bhood03 New Member
    Good question! I was about to ask the same...
    What will happen if i remove the Baffles from my pipes?
  8. T wrecks
    T wrecks Junior Member
    988
    Ditto!! :yes
  9. Mainah
    Mainah Junior Member
    471
    I put Progressive airtail shocks on my Softail and my buddy put a legend system on his. I would recommend either one. As far as the regular shocks, my son in law had Progressive shocks on his Softail Custom and liked them a lot.
  10. glider
    50
