lowering a 1997 road king
Discussion in 'Touring Models' started by turbo kid, Mar 29, 2009.
  1. turbo kid
    turbo kid New Member
    Hi just picked up a 1997 road king and am looking to lower it in the front and rear.Whats the best way to do it please.Thanks Dan
  2. Bud White
    3,270
    this has been talked about a lot do a search there are many options
  3. Caper
    Caper Active Member
    236
    Lotsa opinions on the best way to lower them. Shorter shocks in the rear and drop it the same amount using a progressive or race tech lowering kit in the front, is the way I'd choose.
  4. TQuentin1
    4,737
    142
    Are you sure that it has NOT been lowered already? Need to check dimensions against the specs in the Owners manual BEFORE you spend a bunch of money.
    Then, does it have air shocks on the back? If so, check the number on the side of the shock to see if it is the original or the lowered one. If original, you can get about 3/4"-1 in off the back with the lowered HD air shocks. Match the front with the HD lowering kit. Not sure if that bike has the cartridge on the left or not. If it does, you might consider changing out the front assy for the '06+ version since you will probably have to rebuild the front end shortly anyway. Get the lowering kit when you do that and lower them before you put them on the bike.
