Lost of power
Discussion in 'Softail Models' started by barnak, Jul 14, 2009.
  1. barnak
    barnak Member
    51
    I own a 08 FLSTC, I had to ride it in heavy rain yesterday for about 100 miles, it started to lost power for a couple second at a time, when I accelarate, especially around 80km-h, I check the air filter, everything is good, took it for a test ride and still doing it, any idea anybody. BTW, I called the dealer and he will take it in next week.
  2. STEVE07
    4,122
    68
    82
    Do you have a blow dryer? if so take the seat off and blow dry everything electrical you can see,don't forget the crossmember on the front of the frame that is where your front 02 sensor connection is,you may want to take that apart,dry it then re-connect
  3. barnak
    barnak Member
    51
    I disconnected the O2 sensor and dry it, but it still doing it, may be not as much as it was before, but not alot better.
  4. barnak
    barnak Member
    51
    Well, after letting the bike dry in the garage and use a air blower, I took it out yesterday and the problem is fix, does anybody experience that before?, I'd like to know wich part could have cause this, thanks
