loosing air pressure
Discussion in 'Other Service and Maintenance' started by speedybiker, Aug 31, 2015.
  1. speedybiker
    speedybiker Member
    29
    13
    Hi,I'm loosing air pressure in the rear suspension of my 2010 RK.
    About 10 PSI a night.
    The valve is ok.
    Suggestions?
    Thanks.
  2. Jeff Klarich
    4,844
    103
    496
    I suspect a leaking seal within the shock, you may want to check the connections where the lines connect. Try spraying some soapy water at all connections and check for bubbles.
  3. speedybiker
    speedybiker Member
    29
    13
    Thanks,I'll do so.
    When the inner seal is leaking,is it replaceable?
  4. Jeff Klarich
    4,844
    103
    496
    My experience with air shocks is if it's a line they can be replaced but if it's an internal issue they are not fixable.
  5. speedybiker
    speedybiker Member
    29
    13
    Ok,clear.TY.
