free website stats program Looking for S&S 570g 2004 FXSTDI | Harley Davidson Forums
I am looking for a pair of S&S 570g cams. With or without the outer gear set. New or used. Thanks!
Be careful. '04 OEM valve springs will not accommadate .570" lift. .510" is generally accepted limit but some have gotten by with .525" after checking for coil bind. '05 OEM beehive springs will accommdate up to .600" lift. Also check crank runout; should be .003" or less to run quiet. ;)
