Loading a FatBoy on a 5x8 landscape trailer
Discussion in 'General Harley Davidson Topic' started by Dan.1977P, Jan 16, 2015.
  1. Dan.1977P
    Dan.1977P Active Member
    287
    38
    5
    I'm planning a move from VA to UT and will be driving the van. I'm wondering if it would be worth the effort to put a tow hitch on it and pull our landscape trailer with the motorcycle and probably our washer and dryer loaded too. Should be well within the limits of the trailer and van but I'm just not sure if the bike would stay put. There are tie downs on the frame and I'd happily put down a wood deck and an more anchors if that would do any good. I have a buddy who has borrowed this trailer to pick his sportster up a couple times but those have been 20 mile trips max.
    Is this a bad idea? It's $700 to ship it even with the hog discount.
  2. Jeff Klarich
    4,848
    103
    498
    I moved from Minnesota to Colorado and hauled mine in a enclosed trailer. I did a 4 point tie down with 2 inch ratchet straps and it never moved a bit. I checked it a few time at gas stops and never had to re -tighten. Check out the self help section as well, I've got a post there about shipping. My brother in law has a freight forwarding company and should be able to beat the price you quoted.
  3. Jeff Klarich
    4,848
    103
    498
    I forgot to mention I also mounted a chock to the floor and that kept the bike straight up and locked into place.
  4. Dan.1977P
    287
    38
    5
    Thanks Jeff, Ill make a couple mods and test it out here before I make the 2000 mile drive with it.
  5. Breeze3at
    Breeze3at Well-Known Member
    4,926
    224
    Make sure the tires on your trailer are rated high enough for the load, also that they are in good condition. Make sure the wheel bearings are well lubed. And take in consideration the tire size and speed you will be traveling. The smaller the tire, the faster they will spin on the Interstate. You don't need to re-deck the entire trailer, a 2" x 6" x 8 ft. under the tires will displace the weight. Chocks and straps in good condition add to the safety of your bike.
  6. kstrohs57
    kstrohs57 Active Member
    131
    The wheel chock is the best thing to haul with that keeps motorcycles from moving around . I hauled my 13 limited from Broken Arrow OK to Ohio with no problem at all . You can pick a wheel chock up on E-bay cheap around $45 with shipping . If your moving in the Spring-Summer then a open trailer works .I would not haul in open trailer in the winter time thru states that put road salt down .
  7. dbmg
    dbmg Guest
    One stop shopping at Harbor freight to get all the accessories needed to securely attach bike to trailer.....
    If properly secured and protected no need to worry for a incident could very well happen with the professional movers..
    The key is to occasionally check tie downs as you travel...
    Keeping bike out of weather would be a better choice of trailer..
  8. Jeff Klarich
    4,848
    103
    498
    Harbor freight is a good choice, thats where I bought my chock and I believe it was less then 50 bucks. They also have a good assortment of hold down straps.
  9. glazier
    glazier Junior Member
    940
    7
    Forget the trailer and ride it out there
  10. dbmg
    dbmg Guest
    That would definitely be a trip of a lifetime....:s
