the speedometer/tach lights on my 2016 Low Rider seem to come on when they want to, any ideas?
wistlepig Member Aug 29, 2020 #1 the speedometer/tach lights on my 2016 Low Rider seem to come on when they want to, any ideas?
gator508 Experienced Member Aug 30, 2020 #2 Possibly moisture or corrosion inside the speedo. I have read here of people drilling a small hole in the back to let moisture out, I would be hesitant to do that without knowing for sure. Im sure others will chime in with suggestions.
liquid_wrench Well-Known Member Aug 30, 2020 #3 Have you checked the wires going into the housing? Maybe loose connection on plug.
Harttoo Well-Known Member Aug 30, 2020 #4 Aren't they photosensor controlled? Only light at night or in the garage.
